Float Button
On a 126, what holds the float button in? Should it be glued or something? I just put one on from an extra lift arm I had, and it doesn't fit tight, it keeps falling out.
they're a pressed fit usually 1 time use only because they collapse a little bit when pressed in ..you could try a little Loctite not sure it will work foy you or not ...
| All times are GMT -4. The time now is 12:45 AM. |
