-   -   Installing a Hydraulic lift on Cub125 (https://www.onlycubcadets.net/forum/showthread.php?t=53761)
jer411us 11-05-2018 08:16 AM
Hi All,
I picked up a hydraulic lift kit for my cub 125. I had a couple questions about install.
I got the old shift handle removed, and i'm getting ready to install the pump.
Can anyone tell me what size belt is needed for the pump?
How do install the belt onto the pulley?
Any recommendation on fluid to use?
Does anyone have any tricks or tips for installing the kit?
Any help would be much appreciated.
thanks
Jeremy
olds45512 11-05-2018 08:36 AM
Can't remember the belt size but I can tell you that you will need to unbolt the engine and move it forward to get the belt around the pulley and driveshaft, you may need to remove the hood and grille housing to give you enough room to move it forward.
finsruskw 11-05-2018 08:53 AM
Ever think of looking here?
https://www.cubcadet.com/equipment/A...5-A/0019250019
Belt is IH-386160-R1
Did you get the correct rockshaft arm for the hydro lift, part #19?
jer411us 11-06-2018 08:03 AM
thanks for the info, I found the bolts are 9/16 for the engine mount, i did have move the cover that mounts to engine under the electric to have enough room to slide it forward.
thanks for the link, i was able to get a similar belt at the napa. It appears the lift pump came with the correct rockshaft arm. I got the pump installed, hopefully today I can get everything tightened down thanks again
CADplans 11-06-2018 01:41 PM
We would really like to see pics of your install,,, :bigthink:
:beerchug:
Cub Cadet 123 11-07-2018 10:22 PM
The install manual states to cut the clutch shield in half. I would recommend that you NOT cut it in half, but notch it around the belt. So you move about 3/4" or so over from center at the top of the clutch shield and cut it back about 1" and then cut it parallel to the edge from the flat mounting platform of the shield.
DoubleO7 11-08-2018 07:20 PM
Don't forget the hydro unit installation and parts modification details are hosted here on OCC.
I has lots of instructions as originally written by IH.
https://www.onlycubcadets.net/forum/...ead.php?t=7429
jer411us 11-20-2018 01:22 PM
thanks all for the help, I got all of the hardware installed for the pump. I had to get new hoses made, and it appears I have a small leak somewhere after running it for a little bit. I still need to re-install the foot pedals. I'll work on grabbing some pics to post them later this week.
