-   -   3 Point Hitch for 3000 Series?? (https://www.onlycubcadets.net/forum/showthread.php?t=53823)
hemimike 11-12-2018 08:44 AM
Anyone know where I may able to find a 3 point hitch for my 3205?
RumbleFish 11-12-2018 09:10 AM
Id try one of the links at the top of the page. Or if you have a bookface, I'm reasonably sure I just saw one on the free auction page
Oak 11-13-2018 12:02 AM
Good luck finding one:angry: I don't know of anyone making an aftermarket version yet so prices are sky high. If you can find a complete one for $500 or less, jump on it, that is about what they bring on EPay. I picked this one up for my 3205 about 6 years ago for $200.:beerchug: There are 2 versions of the hitch for the 3k tractors. The early version with the twin disc brakes take the 365 hitch and the later machines take the 207 hitch.
Attachment 96675
hemimike 11-13-2018 04:04 AM
Thanks the heads up. Mine has twin disc. I'm a metal worker, so even if it was close, I could probably make it work. I'll keep my eyes open I guess.
TNTs CC 11-13-2018 11:32 AM
I think I've read the later 207 kit will fit on the older models but not the other way around. I believe the redesign was done because the inboard mounted brake required a new kit due to clearance issues by the rear axle.
:bigthink:
hemimike 11-13-2018 01:52 PM
I've seen a few for John Deere's, sorry for the profanity:ExtremeFunny:, that I wondered if I could fabricate to make it work. We'll see how desperate I get.
Oak 11-13-2018 07:15 PM
5 Attachment(s)
Fabricating the metal parts wouldn't be very hard to do. The hard part would be getting all the other stuff figured out. The two hoses going towards the bottom of the picture go to the cylinder.
Attachment 96682
You will need a valve block from a Cyclops or 3k machine like this.
Attachment 96684
You will need one of these to couple it with the mid mount lift block.
Attachment 96683
You will also need the lift link and lever for the valve.
Attachment 96685
As I said, it is possible to do but there are a lot of tight bends on the lines that are stuffed under the fender pan.
Here are some of the parts needed for a factory looking setup. You will need to fab the lift cylinder too because it is special to the rear lift.
Attachment 96686
Good luck and let us know how it goes and don't forget to take lots of pics for us.:beerchug:
ejl6658 11-14-2018 08:37 AM
3 point hitch for 3000 series
Nice looking 3205 Oak. Do you still have it?
hemimike 11-15-2018 04:02 AM
I agree. Mines pretty rough, but it gets the job done.
Oak 11-15-2018 08:39 AM
Thanks guys. Yes, I still have it and it is my go to mower but not this year because it has been in my shop for a rear end leak. I hope to have it finished soon.
