-   Kohler Engines (https://www.onlycubcadets.net/forum/forumdisplay.php?f=50)
-   -   CH25S MDI tach? (https://www.onlycubcadets.net/forum/showthread.php?t=53906)
RAC65 11-23-2018 01:23 PM
CH25S MDI tach?
So this was really a Simplicity question
(begging forgiveness), but I think there are more folks here than on that forum and the Kohler ch series v-twins are the same either way so I'll pose the question here. I have a ch25s that the original ignition went bad on and of course replacement parts are no longer available and the update to the MDI ignition was required (new flywheel & coil packs). The problem??? NO provision for tach hook-up! Kohler says "sorry, you're out of luck". But I'm thinking there has to be a way. Ideas? The factory dash tach requires a high voltage signal spike (similar to an older tach that would hook to the negative side of a ignition coil)
RLause 11-23-2018 03:15 PM
You might try to wrap the pickup wire 4 or 5 wraps around one of the spark plug wires.
ol'George 11-23-2018 04:56 PM
Sure worth a try, I wouldn't thought of that.:bigthink:
Other wise one of those cheap tiny tacks from China will give you RPM's
cooperino 11-23-2018 05:17 PM
If you do that on a twin you will need to multiply the number by 2
ol'George 11-23-2018 05:40 PM
That is too broad of an assumption.
Some 2 cylinder engines fire both plugs @ the same time.
I.E, a wasted spark design/system.
I can think of several that fire both plugs @ the same time.:bigthink:
You would divide .
Also 2 stroke vs 4 stroke
cooperino 11-23-2018 06:15 PM
You would divide .
You are correct. I should have been more specific. I was really replying more to this specific case in point.unless im mistaken the ch25 is not wasted spark correct?
ol'George 11-23-2018 07:44 PM
coop, I have no idea, I'm old skool, never had my crepey fingers on one.:bigthink:
RLause 11-23-2018 07:49 PM
You are correct. They have 2 coils
Gompers 11-23-2018 10:25 PM
I believe it is wasted spark. I can't think of a Kohler twin that you'll find in a cub that isn't wasted spark.
All of the Magnum and KT engines are. There are two separate coils on a CH, but they both fire every time the flywheel goes past them.
cooperino 11-24-2018 08:48 AM
So... there are 2 coils. They are triggered by the flywheel passing the coil. Theres only one magnet on the ch25 flywheel. The coils arent mounted togerher. So how could they fire at same time ?
