-   -   Fitmeny question .... (https://www.onlycubcadets.net/forum/showthread.php?t=53970)
Gr8lite 12-01-2018 06:30 PM
Will a plow frame from a 1811 fit properly on a 1872?
darkminion_17 12-01-2018 06:38 PM
No, check here.
https://www.cubcadet.com/webapp/wcs/...0-A/0065900001
R Bedell 12-01-2018 07:50 PM
My son has a 2072 (SGT) that he is using the typical GT IH 54" Dozer Blade on....BUT....it was modified. The Sub Frame arms were lengthened, the Lift Arm on the A Frame was extended, and the Lift Rod was custom made. I am working with him presently on this project to take out the poorly "cobbled" modifications and make it look more professional.
BUT Lew is right. The IH blade was NOT intended for the SGT Tractors.
Gr8lite 12-01-2018 08:48 PM
Thanks , so I guess I’m still on the hunt .....
Sam Mac 12-01-2018 09:05 PM
Unless you are will to play with tools and a welder you are looking for a 54" Snow Blade 190-401-100 :beerchug:
Gr8lite 12-03-2018 07:20 AM
ok , thanks guys !
In scouring the interwebs looking at just about every available picture of an 1811 and comparing to my 1872.
Am I correct in saying that the front of the frame(steer axle forward) is the
same on the 2?
And that the major difference is in the wheelbase / length of frame?
So a front blade attaching points are the same but the shorter frame length of
the 1811 will not allow the rear mounting points to be correct?
R Bedell 12-03-2018 08:06 AM
YES..........Plus, the Bracket on the Dozer Blade "A" frame may have to extended, and the Lift Rod will also have to be extended.
The correct Dozer Blade for the 1872 was the 190-401-100 54" (Haban) Blade.
Gompers 12-03-2018 08:26 AM
Yes that’s basically right. The factory blade for a super is a 54” one I believe was made by Harban. It’s black and not white. The white 42” and 54” IH blades weren’t made to go on the supers, but it’s not a huge job to extend the subframe and lift arms if you’re handy with a grinder and welder.
R Bedell 12-03-2018 08:51 AM
Here is a Picture of the "401" blade.
Sam Mac 12-09-2018 05:52 PM
Here is what you are looking for.
https://www.facebook.com/Hauck-Enter...ref=nf&__xts__[0]=68.ARBpEPMeeNokY8X3VwVKRWPnH03fOm8gnecO0F31xjEyhe ApMYedhftUfqqCrXFISzcMziHz2Qez2-DcHiwAHmmt71LVBWMB5krgw2yXFJ8sVsSRtO8fepYEqK_U8W2w KTdT5P6xKINsTbRa-mKrXek_oPmr6GylAiHuONescuBWb6VR1BYzZt-c-HaXvhpTPSF6N2Q0My4-22a09rg8jZzHahRpEvJ_cFuROletWRk335yzPxrE7ut3xuS6t6 8ADe0fZsy18BBXhaxyN-3tEIFn7tnCD57tcUXMUA1-v3ZgieH5j9prUpzKSG5MWpM3EOquqOlbdaipODJY5HZjo6EL5s N8M7AifApJgfZ9kW0SUr1_XQ
