LED light bar
I bought an OTC cab for my GT3200 with a 45" snowblower because I've gotten tired of looking like Frosty the snowman after blowing the driveway with shifting winds. I would like to put a LED light bar on the cab for additional lighting. Did some searching and found many from cheap to very expensive with reviews from junk to great. Does anyone have a recommendation for a quality LED light bar?
Keep in mind that an LED light will not melt snow that sticks to it as they don't generate any real heat.
I have a close friend of mine, that is a Foreman for the Local County Road Commission, stated a couple of weeks ago, they are finding their new LED warning lights have a downside to them. They don't generate any heat in the winter months on these lights. Thus, they are finding the ice/snow stick to these lights and they have to constantly keep them clean. They are going back to the incandescent lights to eliminate the icing problem. Seen a LED light bar on another forum. I don't recall any comments about the winter performance.:bigthink: |
Bear in mind, this statement was made from someone using their equipment for extremely heavy use, plowing snow. Personal use is obviously a whole lot less and the extent of cleaning will be less also.
I have a Sims cab on my 3240 w/snow blower and will be getting LED lights for it as a Christmas gift. I'll update the thread when I try them out.
If there is less then about 4" of snow I just plow it quick with my GT3204 instead. |
I installed some of the Red Oval Rear Taillights on my Trailer about 5 yrs ago. This summer I found that both were partially working. I ordered in two new taillights. When swapping them out, I found out why they turned bad. ----Water inside ----. How does water get inside a sealed taillight assembly..???
:bigthink: Needless to say, I applied a bead of clear silicon around the mating edge of the lens and the housing, on the new pair. |
Good points for you to consider.
| All times are GMT -4. The time now is 02:28 PM. |
