-   -   Hard time finding plow attachments (https://www.onlycubcadets.net/forum/showthread.php?t=54337)
rslyger 01-20-2019 10:27 AM
Hey everyone, I am having a very hard time finding a complete snow plow attachment for my 1861. Around Ohio they are very hard to come by a I guess. Anyone have any ideas on where to locate one or possibly selling one themselves?
Gompers 01-20-2019 11:57 AM
What kind of snow plow are you looking for? 42" wideframe plow attachments are extremely common just about anywhere.
RLause 01-20-2019 12:06 PM
Go to Craigslist and do a search for Cub Cadet and you should find a 1/2 dozen
RLause 01-20-2019 12:08 PM
https://toledo.craigslist.org/grd/d/...791662744.html
dale c. 01-20-2019 01:02 PM
the mount frame on the plow in the last post is for a wide frame but not a cyclopse
wjamesm 01-20-2019 01:56 PM
Not to highjack this thread but whats the difference between a wideframe and a cyclops frame ? I had a 1812 that had a 551 snowblower and I reused it on my 1864 and it was slightly different , After mounting the blower to the 1864 I had no room to put the pulley cover on the snowblower itself back on like I could when it was on the 1812 .
Gompers 01-20-2019 03:43 PM
They are basically the same frame. The cyclops one has a few additional holes, IIRC. The bodywork is different though and that's where you'll run into clearance issues.
Gompers 01-20-2019 04:13 PM
Yeah it will fit with a little bit of grinding, but the cyclops subframe is a little different. The blades are identical though.
I don't see as many cyclops blades floating around, but the subframe would be pretty easy to modify to fit properly.
rslyger 01-20-2019 08:16 PM
I have been searching Craigslist face book and other places. I should have put in the tread earlier I am not sure on which mine calls. I got the 1861 last summer from a friend and know nothing on it except I can not find another mower built as strong. I have spent the past three months restoring it back to new and have no clue what plow I need. Yeah now there's a ton of snow on the ground I am trying to find one... typical huh.
rslyger 01-20-2019 08:25 PM
I have found a 190-302-100, plow about 3hrs away but not sure if it will work for my 1861 any idea?
