D600 head gasket
I blew my head gasket on my 1572 and need some gaskets. Does anyone know of place to get like a gasket kit for the D600? I have tore down my 1572 for painting etc. Also has anyone use porch electric wire kits for the 1572? Bluford IL
Here it is:
https://www.partstree.com/parts/cub-...cylinder-head/ Part number: Cub Cadet KB-15862-03310 And here's one on Ebay: https://www.ebay.com/itm/Kubota-GASK...frcectupt=true |
The Part (KB-15862-03310) is available from your local Cub Cadet or Kubota Dealers. If that is not practical, you can try the Sponsors at the top of the page. Then there is always the online sellers.
Can you buy the head gasket as a set? I will also need valve cover gasket as well and misc gaskets. Thanks Bluford IL
Go to the top of the Page and click on the tab that says " Cub Cadet Parts & Service Look up ". Plug in your model number (1572) and pick the section of parts you are interested in.
:IH Trusted Hand: |
Got it. Thanks
buy it at Kubota lot of times it cheaper
Cheaper to buy the entire gasket set at around $120 than to buy one or two pieces. Kubota parts aren't cheap.
