-   -   127 stalling (https://www.onlycubcadets.net/forum/showthread.php?t=54462)
DL127 02-08-2019 06:50 AM
127 stalling
I have a Cub Cadet 127 that I have owned for a couple years. I bought it from a fellow that had no information about any service or repairs it has had.
I installed new genuine Kohler points and carburetor kit. Set the points and adjusted the valves and governor. The engine starts effortlessly within 1 or 2 seconds at any outdoor temperature. It idles great and will run all day at 1/4 throttle or less. But if I move the throttle past 1/4 position the engine speed will increase, run for 30 seconds or so and die. The more wide open I move the throttle the faster the engine stalls out. It refires and runs great the instant the throttle is lowered and I hit the key. I bushed the carb throttle shaft, rechecked the float and rechecked the intake and exhaust valve setting. I have not pulled the cylinder head so I don't know the condition of the valves etc. Any advice would be greatly appreciated.
Thanks DL127
dale c. 02-08-2019 07:26 AM
sounds like a fuel problem , check the settlement bowl theres a screen in it . make sure it has good fuel flow out of the tank
ol'George 02-08-2019 07:49 AM
Try enriching the main jet screw 1/2 turn and see how it acts after you check the fuel flow as suggested.
Also,
many times a piece of foreign material ( IE.fuel line hose) will become lodged in the fuel inlet fitting at the carb that leads to the needle valve.
Does pulling the choke help?
Another thing comes to mind:
A bad condenser can and will allow an engine to start normally and idle
at slow speed all day long,
but when the throttle is advanced, it will not rev up and will act like a fouled plug/missing/sputtering.:bigthink:
R Bedell 02-08-2019 08:53 AM
I agree with the others. There is some sort of Fuel Problem.
DL127 02-08-2019 12:59 PM
I replaced the condenser at the same time I replaced the points. I fabricated a stainless steel gas tank from 4" pipe, removed the settling bowl and installed new tubing, an inline fuel filter and petcock. I'm stumped. It has done this stall out thing since day one. When I rebuilt the carb I dismantled it and ran it through an ultrasonic bath cleaner and blew compressed air thru every port or hole I could see. I'm convinced it's fuel related as well but other than out right replacing the carb I don't know what to do. The only ignition part I haven't replaced is the coil. I haven't tried pulling the choke before it stalls. I will try opening the high speed screw 1/2 a turn.
R Bedell 02-08-2019 01:51 PM
Again, it is a FUEL issue.
Try running the tractor with the Gas Cap off. See if it is a "venting" issue.
RLause 02-08-2019 04:28 PM
The inline fuel filter could be a problem. See what kind of flow you get thru it.
budscub 02-09-2019 06:33 PM
Agree with R laruse
I would try a piece of hose straight through without the filter to eliminate this first. There is a difference filter to filter. if the filter has a check valve in it may require a fuel pump to flow, and gravity may not be enough to open it. Won't really cost you anything to try. if that's the problem investigate a free flowing ( gravity fed) filter
Bamafan 02-09-2019 08:02 PM
What RLause and budscub said. I had the same problem on my 129.
DL127 02-14-2019 05:28 PM
Installed a different carburetor. Engine still stalls out. What diameter fuel line should my 127 have?
