-   -   1782 Brake Switch (https://www.onlycubcadets.net/forum/showthread.php?t=54809)
rmilcic 04-08-2019 11:27 AM
1782 Brake Switch
2 Attachment(s)
Hi New to the forums. Just purchased a 1782 Cub with the d640 Diesel. When attempting to start, the light on the dash pops saying (depress left foot pedal).(the pedal was pressed and plunger was pushed in on switch) I traced it down to what looks to be a bad plunger switch. (Continuity test with switch out, See pics) Does anyone one of the make\model to replace this? Appreciate all the help!
cubs-n-bxrs 04-08-2019 11:45 AM
I think the part# you need is 925-3191A. That is the switch plunger for your model tractor. Ebay has that switch for $21.99.:beerchug:
R Bedell 04-08-2019 11:49 AM
Ditto, I agree.
rmilcic 04-08-2019 12:12 PM
Thanks guys! Just purchased! Hope this does the trick! I will keep you posted.
rmilcic 04-11-2019 12:51 PM
Anyone happen to know whats ports will have 12v. on the harness for this switch at Key-on? Switch should be here late Friday or early Sat. getting excited!
cubs-n-bxrs 04-11-2019 04:24 PM
In the run position terminals 30&AC should have 12v. In the start position 30,50,17&AC will have 12v. In the glow plug preheat position 30,19&AC will have 12v.
30=Red
AC=Red with white tracer
50=Red with Black tracer
17=Orange
19=Yellow
rmilcic 04-12-2019 06:53 AM
30=Red
17=Orange
19=Yellow
You are the man! Much appreciated sir. My switch should be here today.
rmilcic 04-12-2019 08:49 PM
Well, I tried these 2 switches new. None worked. Dash lights up saying press left foot pedal.. plunger on switch is pressed in.. Funny thing is i was able to jump the harness legs and it starts right up with the key..
R Bedell 04-13-2019 06:48 AM
Here is a schematic diagram of the 1782 Start Circuit. The diagram is color correct and in the proper sequence. Hope this helps with diagnosing your problem.
rmilcic 04-13-2019 09:33 PM
Thank you. I was able to jump switch and everything works. Bought 2. Plunger switches. Not buying anymore..
