-   -   2182 rear wheel spin (https://www.onlycubcadets.net/forum/showthread.php?t=54817)
cruizer2182 04-09-2019 04:28 AM
When mowing with my super when the turf is damp or wet while turning my rear wheels spin and tear up my lawn, speed makes no difference. I know my RPM's are high when deck is engaged but that's the nature of the beast. Would wheel weights or fluid such as antifreeze or washer fluid fix the spinning wheels or compound the problem. A tractor with this much power (2182 with Kubota 3 cyl. gas) is new to me. thanks in advance for your comments and adv
Momma: How highs the cub count hun? 3 cubs and rising Momma
Leadslingingdaddy 04-09-2019 08:17 AM
Put ags on it...
R Bedell 04-09-2019 08:20 AM
I run Ag tires and wheel weights on my Tractor.
cooperino 04-09-2019 08:52 AM
I am a little confused here. Is this happening on a slope or in a spot that you can't ease into the forward motion? Engaging the hydro even on wet grass at high RPM still still be controllable if your not fighting a hill or something. Or is there something out of adjustment possibly on your tractor? I once owned a Kubota sub compact with at least as much power if not more and was easily able to control wheel slip on damp grass.
I could see while turning if you were mowing at a good pace and not pulling back on the hydro in a turn how this could happen... But that would be operator error IMO
ol'George 04-09-2019 08:57 AM
To answer your question, loaded tires and weights on any wheel always improves traction.
That said, mowing wet grass is never recommended for many reasons,
as it sticks to the underside of the deck, and does not distribute clippings evenly are just two reasons.
Also it is recommended to go slower to prevent wheel spin.:beerchug:
cooperino 04-09-2019 09:01 AM
That said, mowing wet grass is never recommended for many reasons.
:High5: What George said!
OH BTW Welcome to OCC!
cruizer2182 04-09-2019 09:11 AM
my problems are on an incline that includes tree's and shrubs, so some tight turning also. I'd never considered ag tires, that may be the route to go for starters. do they ride much different than turf tires. I'm sure on pavement they'd be a bit rougher riding, but I'm not on hard surfaces much.
ol'George 04-09-2019 09:14 AM
If you spin Ag tires, you are going to do more than make a bare spot on the grass. :bigthink:
Edit:
Try weight first before trying Ag's
cooperino 04-09-2019 09:44 AM
Again, I agree with George.. I would probably stay away from mowing when wet in your situation. I do my wet often however my property is really flat. Wet incline with turf tires = slippage. Wet incline with AG's could = deep muddy ruts in your grass. As George said there are a lot of pro's to mowing when grass is dry.
PS.. just thought of this after looking at your pictures.. How much pressure are you running in those turf tires? From the pics the center tread looks raised maybe indicating over inflation. The will aid in spinning for sure.
Sam Mac 04-09-2019 10:42 AM
I ran loaded AG's on my 2182's and 1782.
Edit: Carlisle Tru-Powers on 10-1/2" wide rims.
