My "new" 149
4 Attachment(s)
I recently bought my first 149. My first hydrostatic Cub, A 1973 model. It has been sitting for about 2 years, untouched. The previous owner said that it quit charging so he took the starter/generator to our local shop and had it checked and was told that it was good. He reinstalled it and didn't proceed any farther. I have not had time to work on it since I brought it home. I thought it had a bent spindle or some other problem with the left front wheel when I found it but after I loaded and hauled it home it now sits straight and level like the other front.
It will be restored. |
Congrats on the 149. Should be a fun an worthy project :beerchug:
149 Restore
Been working on my 149 for over 4 years. Not doing a full restore, just making every thing look good and all mechanical things right. Hope you are faster than me and congrats on the 149. They are great tractors. Have a great day.
Bob |
Nice find! I’m just finishing up a restoration on my 149.
Bonus is that it has OEM lights. The headlight panel is worth $100-$200 and the tail lights are worth about the same. Nice find! Definitely worth restoring.
That looks like a nice one. Yes, rare to find the rear lights in tact for sure. That will clean up nicely
I now see what the non-charging problem might be. The voltage regulator, being mounted so close to the battery, is very badly corroded. Might not be the problem, but I guess a good place to start, knowing the starter/generator is good. Wonder how interchangeable the regulator is with others? I hope to get started checking this 149 out very soon. I'd like to hear it run for the first time. |
Congrats on the 149. Keep us posted on what you find out...
Working on the 149 some today, it's obvious the PTO clutch has a problem. One of the set screws is rounded out so I will have to drill it out, I suppose. I talked to the seller today and he told me there was another clutch and some more spare parts that I failed to get when I bought the tractor so I will go get them tomorrow. The engine turns with the starter so I cleaned the points. Next, I will clean the carb and tank and see what happens.
