| FrankF3 |
06-02-2019 05:13 PM |
1772 Front Axle
I had to do some work on the 1772 the other day. In order to get what I needed done, it was easier to pull the front axle off. While doing that wasn't bad, I was surprised what appeared to be a washer-shim between the backside of the axle and the hanger for the axle and 2 washers that go on the pivot bolt just underneath the castle nut. I looked in the parts book and found no such parts, and then looked in the chassis manual and came up blank also. Has anyone taken a front axle off of their 1772 or possibly 1572 and found the same? Could this be a PO modification?
