Engine mounting spacer.
Is the spacer steel/rubber? Also when checking the transaxle fluid, should the dip stick be setting on top of the fill tube or screwed down? Thank you for your time.
:American Flag 1: |
which motor do you have?
What model of tractor are you working on..?? :Huh:
Thank you for your responses. CH18, in a 1864. The dipstick ? is for the hy-tran fluid in the rear end. :American Flag 1:
The little bit of difference in capacity is insignificant,
I've seen it described both ways :bigthink: On my old Ih tractor they tell you if your using the tractor as a stationary unit and it is pointed down hill, pour in another 5 gallon pail of hytran.:beerchug: |
2 Attachment(s)
You need 4 spacers for the CH in an 1864
Thank you, everyone, for your replies. :American Flag 1:
| All times are GMT -4. The time now is 08:43 AM. |
