-   Kohler Engines (https://www.onlycubcadets.net/forum/forumdisplay.php?f=50)
-   -   Baffle gasket necessary? (https://www.onlycubcadets.net/forum/showthread.php?t=55458)
MBY852 07-14-2019 06:30 PM
Have a question. Is the baffle gasket on the carb necessary? I had a carb from a old Allis Chalmers 410 that I removed and put on my 127. It is the same exact carb. The reason I'm asking is that I put a rebuild kit on the carb from the AC 410 about 5 yrs ago and before I got the 127 running again I took the bowl off and cleaned the carb but tore the baffle gasket and didn't put it back on. It runs fine and there are no leaks so that's why I'd like to know the purpose of that gasket.
MBY852 07-18-2019 08:51 AM
I looked in the Technical library and couldn't find anything. Is there another section I might find the answer?
R Bedell 07-18-2019 09:01 AM
What do you mean by "baffle gasket"...??
:bigthink:
ol'George 07-18-2019 09:06 AM
I'm just "baffled" about this gasket thing :biggrin2:
CADplans 07-18-2019 09:06 AM
I guess no one knows what a baffle is that you have located on a carb?? :bigthink:
Do you mean bowl gasket?? :bigeyes:
I am sure that the bowl could work without a gasket about half the time,,
the bowl gasket is kinda an insurance thing,,
making it positive the gas does not leak if the tractor is parked on a steep grade?? :Huh:
MBY852 07-18-2019 09:14 AM
The one on the left they call a baffle gasket.
ol'George 07-18-2019 09:15 AM
Possibly the "baffling" thing is the gasket between the bowl and carb where there is also a square "O" ring located.
I believe it is to help reduce the splashing of fuel in the bowl.
If you find it works in your situation without it, I see no real problem.:bigthink:
MBY852 07-18-2019 09:15 AM
Good one!:biggrin2:
MBY852 07-18-2019 09:22 AM
OK, sorta makes sense. The original carb on the 127 didn't have one and it ran without one. :ThumbsUp:
MBY852 07-18-2019 09:29 AM
Thanks, OK I've never ran into that problem here because a steep grade in Fl is non existence situation.
:Thanks:
