Kohler K301A
Does anyone know if the Cub Kohlers fit in other tractors? For example, I have a 123 and a 125. Will the Kohler K301A from one of the Cubs fit in a Case 222 with the same number(K301A)? I heard something that they can’t be swapped because Cub used a different shaft. Thank you’
Welcome to OCC.....:Welcome2:
"Generally speaking" Kohler builds various versions (Specification number) of a basic model for different OEM's. A K301 in a Cub Cadet will be different than a K301 in a John Deere, and so forth. Crank size & length, Carb, Oil Pans, and cooling are a few of the variations. BUT.....with a little ingenuity, engineering, modification(s), metal, cutting torch, and a welder, something can be done to make it fit. |
2 Attachment(s)
| All times are GMT -4. The time now is 11:48 PM. |
