Voltage Regulator Connection Questions...
I tried asking this on Facebook and now I'm more confused than ever...maybe I will ask better here.
I picked up a new voltage regulator and wire harness for my 149, I was going thru the connections here at my desk and nothing appears to line up between the notes on the wires, the terminals on the regulator and the wiring diagram. I have 3 wires coming out of the harness that are labeled "voltage regulator". The tag goes on to say Gray-"Batt", Blue-"A", Yellow-"F" The diagram I have (from Technical Doc section) shows a Gray wire going to "B", Blue wire going to "G" and a Yellow wire going to "F" The Voltage regulator has a "GEN" terminal, an "F" terminal, a "BAT" terminal and an "L" terminal From this I'm fairly confident that the Yellow wire should go to the "F" terminal. I think the Blue wire should be going to the "GEN" terminal and the Gray wire should be going to the "BAT" terminal, but not very sure about this...and I have no clue what "L" is for. |
"L" terminal is for lights, most applications do not use it.
F= Field--- small terminal on S/Generator Gen or A, --Armature, goes to larger terminal on S/generator. Batt goes to bat terminal. just make sure you go by labeling on the regulator lugs, not the location of them, as various manufactures locate them differently. |
I've most often seen the word "load" associated with the L terminal. If your schematic doesn't use the L terminal just ignore it.
A wild guess for using the L terminal rather than tying all loads to the battery is the L may be regulated to about 12 volts, while the battery charges up over 14 volts. But I pulled that one from you-know-where. |
According to Cub Cadet, the "L" stands for Load. That V/R was only used on the Original and 70/100 series tractors. All subsequent models did NOT have the L terminal.
Per the Factory Wiring Diagram B = Grey Wire G = Blue Wire F = Yellow Wire GRD = White Wire |
| All times are GMT -4. The time now is 04:33 PM. |
