-   -   Hydro adjust (https://www.onlycubcadets.net/forum/showthread.php?t=56533)
john hall 02-27-2020 08:05 PM
Hydro adjust
On my 2284 the only way I can get reasonable reverse speed is to adjust cam pivot bracket way low. Service bulletin says flush with top of washer over the slot. It was already lower and would barely back up sometimes. After adjusting to get decent speed I adjusted connecting rod to neutral of rear and the dash. Now it has full forward speed with lever 2/3 the way up. Linkages and pins look great. The trunion looks too good. No wear as in maybe replaced? I went ahead and changed springs and buttons. Also 1 ball joint appears replaced. Any ideas as to
the odd adjustment or just run as is?
john hall 02-27-2020 08:29 PM
Also there are 2 holes for the linkage, which one is correct?
darkminion_17 02-27-2020 09:23 PM
I would move it to the top hole in the cam plate, see if it makes a difference.
john hall 02-27-2020 09:41 PM
Thinking the same thing. It's cold by Southern standards and I had the heat on, so no raising the door up to run it tonight so I could re adjust.
So I spent the evening trying to get the right hand brake pedal unstuck--its still stuck. Wish I would have seen this before I put the fuel tank back in. Hot wrench would have helped.:bigeyes:
guido 02-28-2020 05:13 AM
Did I read you correctly that you stated that one of the ball joints appeared to have been replaced?
Just a thought... Is it possible that the connecting rod needs some adjustment?
R Bedell 02-28-2020 07:16 AM
I was thinking along the same lines, but with the entire linkage.
john hall 02-28-2020 12:26 PM
I adjusted that as well. Going to start fresh by moving the connecting rod to the other hole and see if that improves things. As it is I get full travel in forward but still not in reverse. Given some of the other things I have found on this machine, it may have been bolted together wrong at some point.
Sam Mac 02-28-2020 08:48 PM
John, you're a member of Cub Cyclops. In the files section is a service bulletin about slow reverse on the Cyclops. The bulletin was provided to me by Lew. :beerchug:
ironman 02-29-2020 07:44 AM
Originally Posted by Sam Mac (Post 493204)
John, you're a member of Cub Cyclops..........:
Sounds intriguing, do you guys have some sort of secret handshake or greeting phrase?? :Shhhh:
Sam Mac 02-29-2020 09:55 AM
Yep.
https://www.facebook.com/groups/666265203510023/
