CC 2180 PTO Belt Problem
I have a Cub Cadet 2180. I've had it since new-13 or 14 years.
It keeps shredding the PTO belt that turns the mower blades. It doesn't just throw them, it shreds them. No warning, it all seems to be mowing OK, then the belt flies apart. I've checked all the pulleys and all are free and bearings good. I've checked pulley alignment and they all seem to be lined up as they should. I've replaced the idler pulleys because they seemed a bit worn. I had it to the dealer and they thought the front of the deck was a bit lower than it should be, so they readjusted to level it up. They couldn't identify any other problems. That worked for awhile, but now it back to shredding PTO belts It's frustrating, I've shredded at least 6 belts over the past few years, and purebred CC Belts are about $40 each at the dealer. I'm tired of it. :bash2: Anybody know anything else I should look at? Anybody else had this problem and found a cure? |
I would carefully inspect every pulley the belt comes in contact with. Look for burrs and imperfections on the surfaces that touch the belt.
I will however, go over them again. I'd LOVE to actually find something wrong so I can finally fix something. |
What puts the tension on the belts, a spring?
that needs to be looked at as if loose, it will cause a belt to roll over then it destroys itself. Also if pulley grooves are worn and look more like a "U" than a "V" it can cause excessive wear/heating and ultimately belt failure.:bigthink: |
My BIL has a 2180 that has the same issue. I adjusted the front of the deck up, didn't help then got looking at it close and it looks like over time the center pulley get's bent forward because the deck bends from the tension on the belt. I shimmed it up to level it and as of now I have not heard of any more problems.
I got another new belt from the CC dealer ($46.77!!!), closely inspected the deck, the pulleys, the drive pulley and the idler pulleys, then put it on. Didn't see anything wrong, didn't fix anything, didn't change anything, just greased the deck, sharpened the blades and put the new belt on. Mowed almost an acre, no issues. Could not have worked any better. Yet Saturday, that same mower didn't go 50 feet before it destroyed the belt. No idea why. I wish I knew why. I am considering that it may be possessed by a poltergeist. A very nasty one. :bigthink: |
