-   -   1914 starter part 2 (https://www.onlycubcadets.net/forum/showthread.php?t=56971)
sbybee 05-10-2020 10:53 PM
1914 starter part 2
I found out the answer to my question the hard way. There is no way to remove the starter on a B48G without pulling the engine. It is more work getting all the shrouds off than the engine out. And I realized it is a Onan instead of a Kohler. steve
R Bedell 05-11-2020 06:44 AM
Even on the Kohler KT-17, M-18, and M-20's are difficult too.
ol'George 05-11-2020 08:49 AM
FWIW:
a while back I put a fuel pump on a 782/M-18 and
decided to remove the shroud on the head to allow better access, and to repair
the missing bolt I noticed by the front PTO area.
Of course that included the upper/lower muffler covers.
So figgered while doing that,I might as well swap the starter I was using for a better one I had.
I was successful fiddling with a couple of extensions/universal joint on the ratshit, for the starter, but when it was all done, prolly would of been easier to just pluck the engine out had I went at the job knowing I was going to do the starter in the first place, and address the missing bolt problem.
---Hindsight 20/20/Monday morning quarterback situation. :BlahBlah:
