-   Cub Cadet Lawn Tractor (LT) (https://www.onlycubcadets.net/forum/forumdisplay.php?f=42)
-   -   Please help with 1015 lawn tractor (https://www.onlycubcadets.net/forum/showthread.php?t=57359)
Leggwilliam95 07-07-2020 10:13 PM
I have a cub cadet 1015 lawn tractor. The numbers I pulled off of it are as fallows:
Model: 138200100
Seriel No: 137667
Mfg date: d148g
I have a number of issues with the lawn tractor deck. When I bought it used off of someone, the blades would not disengage. I was told to replace this sleeve in this bracket that puts tension on the deck belt when engaged. I did this repair and it cured some of the problem but blades still kept wanting to turn.
Now two of those connections came apart and cut my belt, and I am unsure how they go back together. also the rear double drive pulley has this arm that has dug into the pulley itself and that does not seem right.
The deck seriel number is 305769 but i cant find info on that ethier.
ol'George 07-08-2020 12:22 AM
Post some pix of your areas of concern, hopefully we can figger out where specifically your problems are.
It prolly would help you if you went to cub cadet parts & service look-up near the top of this page, and plug in your make/model where they ask and you will get a parts picture not only with part numbers but where parts are located and what they are called.
That way we are more able to help,--- and you learn where your problem is, ------hopefully.:beerchug:
