-   -   3225 vacuum actuator (https://www.onlycubcadets.net/forum/showthread.php?t=57608)
ALA3225 09-02-2020 12:09 PM
Anyone know what part can be used to replace the vacuum actuator on a 3225. Parts tree says the 759-3963 is no longer available
Mike McKown 09-02-2020 01:32 PM
https://www.google.com/search?source...RQkCsgQ4dUDCA0
ALA3225 09-02-2020 02:22 PM
Can't order it says part has been discontinued
Billy-O 09-02-2020 03:25 PM
Used one on Epay:
https://www.ebay.com/itm/Cub-Cadet-3...0AAOSwrxBfSm12
Mike McKown 09-02-2020 04:08 PM
I found you one. Call Johnathan at Jacobi Sales 812 365 6141. They have one left in stock.
Oak 09-02-2020 04:36 PM
There is a replacement kit now. Yours probably has the steel bracket that holds the actuator. That style has been replaced. I’ll see what I purchased when I changed mine on my 3205.
This should work but in the kit you also get the solenoid assembly to remote mount it from heat and vibration.
https://www.amazon.com/MTD-Vacuum-Ac.../dp/B084G79RW4
Yardman 04-15-2023 12:12 AM
3225 vacuum for pto
Where does the vacuum line that controls the pto actuator originate from in the engine? Installed replacement engine that doesn't have the vacuum line coming out of engine.
R Bedell 04-15-2023 07:18 AM
What model of tractor are you working on and what engine did you put in ???
:Huh:
ejl6658 04-15-2023 08:45 AM
The intake manifold.
Yardman 04-15-2023 09:35 AM
Thanks for responding! I replaced the original engine on my 3225 with a Kohler PA-CH740-3328. It does not have the vacuum line running from the intake manifold. Would drilling a hole into valve cover, install a fitting and line work? I can use the old cover from previous engine. Btw, the original engine threw a rod. I hope this new engine will last until I go horizontal! Thanks!
