-   -   Disc: Drag or Sleeve Mount? (https://www.onlycubcadets.net/forum/showthread.php?t=57849)
Ambush 11-07-2020 03:55 PM
New here and new to tractors. I just bought a 1973 CC 149 (with hydraulic lift) that I intend to use on a one acre food plot. No rocks and few roots, mix of clay and light soil.
I'm also in the process of rebuilding/moding an old set of drag discs. For a few years I've been pulling a four foot section of the disc behind a quad,with fair results. I say fair, becauses sometimes there's too much penetration and sometimes not enough.
Since I'm going to be building a frame for the disc anyway, I can either build a tandem drag or a single row for a sleeve hitch. I'm thinking the sleeve hitch set up would allow me to use the tractor's weight to advantage? What would be the advice from those that have used either or both? If I go tandem, then I would still pull it with the quad to speed things up.
I also have a IH #2 tiller with the tractor, but the mule drive, gearbox and mounting bracket are missing. I'd like to find the tiller mounting bracket, but likely won't be using the belt drive system. I'd also be thankful if someone that has that bracket could give me the dimensions so I could fab one. I have to build a sleeve hitch also.
Since I have no intention of ever using the PTO for belt drive, that will be getting a hydraulic pump for a dedicated system, which will also drive the tiller, much like the case 446.
A ton of Cub knowledge pooled right here on this site and I hope to mine some and hopefully contribute some.
Thanks!
Rod.
R Bedell 11-08-2020 06:27 AM
I like the idea, that one could pick the disk up with the hydraulic lift, to transport it to the area of tillage.
:ThumbsUp:
Ambush 11-08-2020 01:23 PM
I'd really like to get the dimensions for the bracket #1 in the pic so I can mount the tiller. Height and hole spacing seems to be fairly critical for the bar mounts. I can use the diff cover as a template to bolt the brackett to the diff housing.
Or if someone has one?
Farmall450 12-29-2021 03:19 PM
My 1711 has an (at least somewhat) homemade one. PM me for details.
Ambush 12-29-2021 09:16 PM
Farmall450, thanks for the offer. Ole'George sent me the dimensions and it is on there and doing duty. I also built the sleeve hitch and adapted a single row disc to fit the sleeve hitch. The tiller got a fourteen horse motor mounted to it and it also mounts on that bracket.
I had a ton of pics but about a month ago I accidently permanently deleted several years of pics. I have to buy a program to try and recover them.
Farmall450 12-30-2021 07:55 AM
It might be easier just to re-take them. Inquiring minds!
Ambush 12-30-2021 09:47 AM
The disc is under two feet of snow out in a bush plot. I have one on my phone but it won't upload. Seems to me I have to email it to myself then resize to post. I drowned my camera on a river crossing in the fall, so the phone is all I've got right now. But if you search my name on the site there are tons of pics of all the work/builds that I did on the 149.
