-   -   Bagger on the 1512 (https://www.onlycubcadets.net/forum/showthread.php?t=57889)
ken6x6 11-16-2020 12:13 PM
Bagger on the 1512
Finally got tired of dealing with the leaves from 3 huge oak tress in my yard. It was time for a bagger. I knew it would be a peice together project since finding a bagger that was intended for my cub would be near impossible. I wound up getting the bagger from a 2500 series, a 46 GT deck from a 1641 and had get to the discharge chute from cub. I had to build my own bagger mount which turned out better then i thought. The discharge chute from the deck is 8.25 inch while the 2500 serires upper chute is 7 inch, so had to make a "custom" connector. All turned out well and it works good. It does fill the bags up quick tho. I found if i run over all the leaves first with out bagging to chop them up the bagger will go longer between dumps.
darkminion_17 11-16-2020 07:52 PM
Came out nice Ken.
drglinski 11-16-2020 09:50 PM
I like it.
Small leaves take up less space than large ones. Enjoy.
Oak 11-16-2020 10:45 PM
Nice job Ken.:beerchug:
ken6x6 11-16-2020 11:10 PM
Thanks guys.
Anyone know the difference between low lift and bagging blades as cub lists them?
