-   -   Are all the steering columns the same? (https://www.onlycubcadets.net/forum/showthread.php?t=57923)
jbrewer 11-22-2020 05:39 PM
I need a steering column assembly for one of the rusty cubs. Did all of the IHC cubs use the same column/ross gear?
Thanks!
John
R Bedell 11-22-2020 06:53 PM
Short answer is............NO.
Basically they are, except..........for tube length.
jbrewer 11-22-2020 07:16 PM
Thanks Roland, What versions were common to the 100? Narrow frames?
John
Cub Cadet 123 11-22-2020 09:49 PM
It depends on the model. I know that not all NF steering columns are the same. It does vary between the models. If you are looking for one to replace or match up with the 100, then I would imagine the 70 or 71 would probably be the best candidates, but you should still check tube lengths.
darkminion_17 11-22-2020 09:54 PM
One from a 582, thru a 1711 will work and are the same height.
drglinski 11-23-2020 08:30 PM
The ones put in the quietlines and newer are longer than the older ones.
jbrewer 11-25-2020 07:53 PM
Thank you all for the advice!
I may have to hunt for one
John
darkminion_17 11-25-2020 07:59 PM
Hunt here. 71, 72, 73, 102, 122, 123 any 82 series, and 100...
