Dash Panel/Columns swap for a 107?
Hi there, new to the forum. I just picked up a 107 that has seen better days, but runs; however, the plastic dash panel is cracked, badly bent tin, and it is from a 106.
I was looking at the models for when IH switched over from a metal column and dash over to a two piece and it looked like a 73 series might fit if I replace the whole column. Does anyone have any experience? Tried to see if anyone has reverted a newer dash to the older style, but fell short. I mostly just want to future proof it and remove the plastic dash component as it would probably break again if I repaired it. |
the 106 and the 107 are basically the same cowl (decals are different) and the same hood because they are from the same series - manual trans vs hydrostat.
in this range the evens are the manuals and the odds are the hydrostats - 1x2/3, 1x4/5, 1x6/7, 1x8/9 the body work is the same within the individual groupings. There are some cross-overs of body parts in multiple groupings |
The plastic dash panel doesn't commonly break unless treated with extreme abuse (or like dropping heavy items on it, don't do that). Making sure there's a rubber or foam lining around where the hood contacts the plastic, makes less rattle and protects the plastic even more. I do believe that if you pull the steering wheel, hydro control, ammeter, and choke, and remove the old broken one, simply mounting a replacement one (and possibly replacement dash tin if you can find one) will do and it shouldn't break.
If you really do wish to have an all-metal 107, I do believe the dash from the 1X2/1X3 series mounts to the frame the same way. You will want the dash from a 123 because it is the only hydrostatic with an all-metal dash. Assuming the hydro control is in the same place on the 123, you shouldn't have much trouble bolting it up and connecting the linkage together |
Needless to say I agree that just buying a replacement dash is easier |
They are pricey on the bay...
https://www.ebay.com/itm/Cub-Cadet-1...gAAOSwuyteg~46 https://www.ebay.com/itm/Cub-Cadet-1...kAAOSwAEJfvZKy |
All of this is very good information. I was pretty sure that there would be a bolt on compatible tower.
My dash has a big crack from the implement lever(someone welded it on crooked and rubs the dash panel and I assume that is the cause and my tin is really poor condition with a big bend in the top right corner. I saw the prices on ebay, and for a piece of plastic that is 50 years old it is pretty high. If I keep a plastic dash, I would use a highly fluid adhesive to fill the crack and repaint and I would have to probably get a new tine, make a new one from scratch, or try to fasten down the bent section on the current one. I think the biggest issue would be the steering column. I will have to try to see if the measurements would work. |
| All times are GMT -4. The time now is 08:33 PM. |
