1782 Cub & Snow Blower
I have my 1782 Cub with liquid filled Tires & Iron weights on the rear. Just bought the 551 Snow Blower. Got it installed today and went out to throw some snow here in PA. I kept getting stuck.. Seems like this blower is too heavy on the front of the tractor. Before I go any further would chains help the rear tires and get me through the snow? I mean I went absolutely no where today. Let me know your thoughts or ideas?
chains, loaded tires, wheeeeel weights, and a cab, help lots on my 782 also :beerchug: |
I have a 2182 (basically gas version of your motor) If you are interested I run a cut down reverse pitch fan that blows the radiator heat towards the operator. I have to snow blow with one cab door open or the heat is too much!
it fit perfect other than the length of the blades which were easy to cut down. I confirmed balance on my blade balancer 12599-74110 Fan - Pusher - for Kubota Engine - OEM - NOS $25.50 on the "bay" I am sure kubota has others that will fit as well. You wont want to use this while cutting grass. The radiator filter/screen and the screens in the side panels will be useless and your radiator will likely clog up. |
| All times are GMT -4. The time now is 03:08 PM. |
