-   Kohler Engines (https://www.onlycubcadets.net/forum/forumdisplay.php?f=50)
-   -   Oil change and is now leaking? (https://www.onlycubcadets.net/forum/showthread.php?t=58416)
That_cub_dude1847 03-17-2021 03:21 PM
I did an oil change on my Cub Cadet Original, and now there seems to be an oil leak all around the lower part engine. I did the same to the rear end a while back. i changed the fluid in it and now the rear end is leaking. What could this be leading to? Do I need a new drain plug or something?
R Bedell 03-17-2021 03:33 PM
You should trace down where the leak is coming from, before you shot gun it with parts.
:ThumbsUp:
