-   -   Shed ramp (https://www.onlycubcadets.net/forum/showthread.php?t=58583)
thadscub 04-17-2021 09:54 AM
Shed ramp
hi
I just got a new shed for my Cub Cadet 122, but I need to make a ramp. It has a about a 16 inch difference from the ground to the floor. What size ramp would I need?
Thad
ironman 04-17-2021 10:38 AM
Prolly one that goes up 16 inches.
thadscub 04-17-2021 10:52 AM
i mean length as i don't know the rise a 122 with a tiller or more deck would go up without scraping
Billy-O 04-17-2021 02:07 PM
I would hazard a guess an say maybe the run be 3-4 times the height! 48 to 64 inches long!
Garyoh5a 04-17-2021 02:26 PM
ADA ramps are 1” elevated in 12” of run. Nice rise, however you’d need 16’ of ramp. 6-7’ of ramp might do the job
mortten 04-17-2021 05:45 PM
Mine rises 12 inches. It’s 5 feet long.
Goofus 04-17-2021 07:18 PM
Your profile shows you in Colorado. If you want to get it out and back in during winter you'll want a minimum of 8 feet but 12 is probably a better number, my 8 feet for a 12 inch rise causes minor problems with traction after an ice storm.
If that's not an issue I'd suggest you mock one up to try with your implements, every mount and every tractor is slightly different as wear, adjustment, condition, tires, etc all can make your set-up clearance different from the next guy.
TheSaturnV 04-17-2021 10:44 PM
Get some scrap OSB and 2 x 4's off a jobsite and run some trials.
Cub Cadet 123 04-18-2021 10:10 AM
That or just make one out of gravel.
Getter-Done 04-18-2021 09:45 PM
A 8 foot ramp (from level ground) would be 9.59 degrees.
You could build a two stage ramp.
This would make the second level of the ramp
an easier transition.
Example Picture
Attachment 108064
