-   -   Reccomend replacing lug bolts with wheel studs and nuts? (https://www.onlycubcadets.net/forum/showthread.php?t=58641)
That_cub_dude1847 04-28-2021 03:37 PM
I have a Cub Cadet Original, and I bought dual wheel adapters for it. The original lugs are too short, and they won't go through the wheel. I tried finding lug bolts that would be the correct size but I can't find any. Should I try replacing the lug bolts with wheel studs and lug nuts so the wheel adapters can reach? It might even be easier to replace the wheel and tires too.
R Bedell 04-28-2021 03:49 PM
Won't hurt a thing.
That_cub_dude1847 04-28-2021 04:12 PM
Originally Posted by R Bedell (Post 508508)
Won't hurt a thing.
Do you think I could use regular bolts with lug nuts as opposed to wheel studs since I have some of those lying around?
Tim.E 04-28-2021 11:24 PM
I have used regular 7/16-20 bolts, screwed in from the back. But I had to grind just a little under the head because the threads didn't go completely to the head. I am talking just something like 1/16" or so. Look at your bolts and you will see what I mean. Other than that,they worked fine. I have also used 7/16-20 all-thread/threaded rod with a thin jam nut in the back behind the flange. I found the 7/16-20 all-thread at Fastenal.
Tim.E 04-28-2021 11:27 PM
Or to keep from grinding, put a washer under the head. The bolt method won't work on later tractors with disc brakes.
Sam Mac 04-29-2021 07:07 AM
I put studs on a 149 I used to own. Got the studs, jam nuts and lug nuts from McMaster Carr
94846A520 jam nuts
98750A474 Studs
4991T964 lug nuts
drglinski 05-08-2021 09:14 PM
94846A520 jam nuts
98750A474 Studs
4991T964 lug nuts
Those make so much more sense than the bolts that IH used.
Kelpie 05-20-2021 09:32 AM
I'm thinking of doing this too. I am assuming the jam nuts are only used on the back side of the flange so the rim sits properly?
