-   -   1541 Mower PTO Wont Engage (https://www.onlycubcadets.net/forum/showthread.php?t=58689)
Rainman4820 05-08-2021 11:56 AM
I hit a small tree root this morning but it was big enough to stop the mower. It wasn't an abrupt stop, but stopped it nonetheless. I let it cool down and it started right up, but when I try to engage the mower, I get nothing. Blades turn freely.
Ideas on where to start troubleshooting?
Thanks
darkminion_17 05-08-2021 12:26 PM
broken belt?
Rainman4820 05-08-2021 06:53 PM
1541 pto
Belts good, when I engage or press the momentary PTO Switch to up position, nothing happens. The light on the dash comes on as usual but no engagement, sounds or anything at all.
Thanks
R Bedell 05-08-2021 06:54 PM
Is the wire connector from the PTO to the Harness Connector intact ??
:bigthink:
Rainman4820 05-11-2021 02:48 PM
PTO Issue
I appreciate the thought but now I don't think its electrical.
I tried to start once again and it kicked over once, there was an abrupt thump and then died. I am going to check further and will get back with my findings.
darkminion_17 05-11-2021 07:30 PM
Sounds like a seized PTO bearing. Remove it and see if the engine will start.
Billy-O 05-11-2021 10:25 PM
Look under deck, again. You did say you hit a tree root. Yes, you did say blades turn freely....but which way did you turn it?
ironman 05-12-2021 07:47 AM
I suggest the logical thing to do would be to remove the PTO drive belt and test run the engine?
You can also check the PTO operation while doing that.
Now you can check the deck spindles and blades for binding, broken, bent with no drag on it.
ol'George 05-12-2021 08:38 AM
Just wondering what the "root" cause is? :biggrin2:
darkminion_17 05-12-2021 12:57 PM
Eventually we will get to the root of this problem.
