High Temp Black Paint
I am needing to paint some tins on a Kroller command. What High Temp black paint have you used with good results?
I use Krylon.
Have you thought about wood stove high temp paint , good for 1200f and you have a choice of colours
Oz |
They have Hi temp Bbq grill stuff, as well as header paint.
I have used header paint and it seems to hold up. If you are painting cooling shrouds, I would think if they got hot enough to cause a paint issue, you have other problems. |
Here we go , a good old American company Stove Bright by the Forrest paint co. www.forrestpaint.com
Oz |
Ah, muffin shields, yep they do get hot.
Then that stove paint or header paint sounds good to me. I knew a feller that bought a wood stove once, said it was oak so it burned near an hour before it was ashes. :biggrin2: |
Used a BBQ grill paint good up to 500 degrees F one time on a muffler shield or some such thing. Paint peeled off quick. Tried automotive engine paint with a rating up to 1000 degrees F or higher; worked great.
Lesson: Apply paint that is rated at least twice the temperature you're expecting. |
| All times are GMT -4. The time now is 02:19 AM. |
