Lost bolt for Cub Cadet 122 lift casting
Hi:
I have managed to lose the bolt that holds the lift bar to top casting on the 3 point lift casting on a 122. Anyone know what size it is? Thanks, Thad |
I'm not sure if this is correct, but what I've found in the Cub Cadet parts and service lookup (link is in the header above) says this..."Screw, 1/2-13 X 1-3/8 C-Z Hex Hd Cap"
I encourage you to use the Cub Cadet parts and service link. Though it does not show the bolt in the diagram, it is in the parts list. |
Don't forget the spacer! hehehehehehehehehehe.
| All times are GMT -4. The time now is 08:16 PM. |
