-   -   CCO rear lift casting measurement question. (https://www.onlycubcadets.net/forum/showthread.php?t=58846)
cub123 06-07-2021 08:56 PM
2 Attachment(s)
Hi guys! I've been messing with the idea of making a lift setup for my Original and made these from pictures off the internet. Now, I'm not sure the measurements are exact, as I figured all the measurements from nothing but pictures. #2A is the one I'm most concerned about, the rest I could probably figure by fitting on the tractor if I had to. If anyone could cross check my measurements I would really appreciate it, thanks!
cub123 06-11-2021 04:48 PM
10 Attachment(s)
I decided to proceed with the calculations I made, I only ended up adjusting a few, so I had it pretty close. I started by making the top U bracket and the lift bar. The best I could tell the lift bar has a 30° bend that the belly almost touches the gear reduction housing at full lift. The U bracket is 2 1/2" x 3/8" steel. Next I bored a 1" hole in a 4 1/2" long piece of 1 1/2" round stock on the lathe. Then I cut two slugs of 1 1/2" stock to weld to the tube. After welding them on I cut the ends off so the tube is centered. Next I forged the upper arm. More in the next post.
cub123 06-11-2021 05:02 PM
6 Attachment(s)
Next I cut off and welded the upper forging on. Then I made some templates for the two plates for the support rib and cut them out. After that I welded everything up and cleaned it up. Finally I bored all the pivot holes out to 3/4" and made the pivot spacers on the lathe. It isn't a perfect copy, but it came out pretty decent. The only thing left is a pin and the lower U bracket.
green407 06-11-2021 05:46 PM
:IH Trusted Hand:
That looks great, thanks for the upload.
I like looking at what others have done and fabricating things for my cubs.
ironman 06-11-2021 09:02 PM
If the History Channel's program "Forged In Fire" concocted anything other than knives and swords, you could be a sure $10,000 winner.
Nice job!
West Valley G 06-11-2021 11:35 PM
Truly a work of art. How fun will that be to employ?
Ken
Rescue11 06-12-2021 12:01 AM
Very nice job!
Oak 06-13-2021 10:47 AM
Great job Ben, that piece looks great. With a forge like that do you make other things too? If so, please post some pics up. I like seeing stuff like that.
Ambush 06-13-2021 12:05 PM
Forging is definitely an art from the past. I'll bet you have some interesting items around the shop that you've created!
CubDieselFan 06-13-2021 07:10 PM
That is a really good job.
