-   -   108 drive plate question (https://www.onlycubcadets.net/forum/showthread.php?t=58914)
rsshallop 06-26-2021 05:36 PM
I'm not sure if I should use lock washers with 1/4" 20 5/8" bolts to attached the drive plate to the drive cup on my cub 108? I can't find anything clear cut in the WF manual to suggest yes or no. Also, I intend to just snug the lightly oiled bolts hand tight (6 or 7 ft-lb). Would that be correct? Guidance would be appreciated.
mortten 06-26-2021 06:35 PM
According to the parts look up it uses lock washers. Looked at my 122 and it has lock washers
darkminion_17 06-26-2021 07:04 PM
What he said....
rsshallop 06-26-2021 07:26 PM
Thank you Doug, much appreciated. Thanks also darkminon17 for the reassurance.
