-   Kohler Engines (https://www.onlycubcadets.net/forum/forumdisplay.php?f=50)
-   -   1450 engine same as 147? (https://www.onlycubcadets.net/forum/showthread.php?t=58945)
dukejm 07-02-2021 02:25 PM
Was wondering if the engine from a 147 or 149 would fit into my 1450?
And if so what modifications might I need to make to accommodate the switch.
Was thinking about rebuilding the 1450 but wanted a spare and/or parts engine just in case.
Thanks
ironman 07-02-2021 03:35 PM
1. The 1450 is equipped with electric PTO. The motor from 147/149 would likely not have the bolt holes for mounting electric PTO.
2. The motor from 147/149 uses starter/generator for starting and external voltage regulator.
1450 has built in starter and alternator with solid-state voltage regulator
The whole electical sysem and wiring is different.
Sooooo.....not too likely
Look here... https://www.onlycubcadets.net/forum/showthread.php?t=22
