38 inch deck
Looking for a pic of the belt tension spring for a 38 inch deck. My deck is white in color and fits the 1405 cub, deck is model #441190. Previous owner used a smaller belt and now im not sure where the spring is suppose to connect to provide proper tension on the correct 63 inch belt.
Try here.......... 38" Deck
Thanks
Thank you! While slightly different this diagram was of a different angle than all others I've seen. Was able to determine someone before me put the bolts on the spindle in the wrong positions. Moved two bolts around and I have a spring mount again.
| All times are GMT -4. The time now is 05:49 PM. |
