-   Home Made (https://www.onlycubcadets.net/forum/forumdisplay.php?f=48)
-   -   Kohler 12hp generator with pull start to electric start (https://www.onlycubcadets.net/forum/showthread.php?t=59165)
SDBOB 08-18-2021 08:43 AM
Anyone have experience on how to add electric start to 12hp, 5k Kohler generator. This unit is very heavy. I used it for our construction business 40 yrs ago. Now I'm 73, I'm thinking why pull, if I can push a button.
R Bedell 08-18-2021 08:48 AM
It is impossible to answer your question, in that we don't know the model of the Kohler Engine you are referencing.
:Huh:
SDBOB 08-18-2021 09:34 AM
Ok I'll have to pull it out if storage. Thank you.
sawdustdad 08-24-2021 10:04 PM
Most generators that are convertible to electric start have starter motors already mounted on them and only need the battery added.
At least my 13hp Honda engined-Northstar 8k generator does. I can start it with just a jumper pack (ground clamp and touch the positive clip to the starter).
But it usually starts on first or second pull, pretty easily.
ol'George 08-25-2021 10:11 AM
Interesting, :bigthink:
Most manufactures save costs by offering a rope start.
They do not equip them with all that it needs for electric start other than providing a batt-tree.
Some manufactures will provide a ring gear on the flywheel if is is part of the flywheel as cast, and some also have bosses for the mounting of a starter motor.
some even have holes in the bosses but not tapped for bolts.
also some engines were never designed for a electric start so no provisions are provided in anyway for a starter/system.
most do not have a charging system if it is a rope start.
There are some 110V electric start that provide no charging system like toro and others, usually on a snow blower/thrower situation.
Most times unless a donor engine is available inexpensively, it is not cost effective to convert to a self starter application.
RLause 08-25-2021 12:51 PM
Sometimes the generator has windings that allows electrical starting.
ol'George 08-25-2021 05:11 PM
I have an onan like that, it has a start winding in the power generator.
it is one heavy SOB and it runs at 1800, not 3600 rpm's
It was built for RV usage in the '70's :bigthink:
it also has a 12 volt starting battery charger built into the windings.:beerchug:
RLause 08-25-2021 10:24 PM
Mine is the commercial version with an eye on the top to hook a crane to.
