Cub Cadet 2182 PTO clutch
I need to replace my 2182 PTO clutch. So far, I have tried eBay and Exteme for a replacement. eBay was a bust and got ripped off. Extreme sent what they said was a correct PTO clutch for a 2182. It was wrong and don't think they know or understand what it takes to make a PTO clutch correct for a 2182. Is anyone out there that has actually bought a replacement PTO clutch for a Cub Cadet 2182 would like to hear from you, with the company used, and your experience with the clutch.
There are three (3) generations of the 2182, depending on serial number range.
Generations 1 & 2 used PTO Assembly 717-3467 Generation 3 used PTO Assembly 917-3389 I don't know, neither does eBay or Extreme, which generation you have. IF..........you go to the tractor Model/Serial tag, on the left hand side of the frame, and tell us what you serial number is, we will tell you the correct PTO for your tractor. |
You folks should really spend a little time learning how to navigate the CCC parts lookup site.
If a 77 year old geezer like me can do it, anyone should be able to do it https://www.cubcadet.com/en_US/conte...rtstream.html# |
Xtreme list 2 different clutches available. Based on serial number. One is 4” for the older model and a 6” for the newer model. Did you call or email them and ask for help?
2 Attachment(s)
If yours isn't burned up just put new bearings in it for less than $20.
Here is how the pto looked on my 1992 2182 when I got it. Attachment 109142Attachment 109143 |
I installed new bearings in my GTX2154LE PTO earlier this spring as well.
finsruskw
guess i will have to pay retail on the pto clutch for a 2182. almost no one and the PTO sellers included -- understand the 2182 clutch is different than the usual lawn mower clutches.
What is the part number you need?
Post some pictures of your original and the ones you purchased if you still have them. Also, post a picture of your serial number tag.
| All times are GMT -4. The time now is 11:40 PM. |
