-   What is it worth ? (https://www.onlycubcadets.net/forum/forumdisplay.php?f=61)
-   -   108 engine with dead tractor attached (https://www.onlycubcadets.net/forum/showthread.php?t=59382)
Wayne 10-20-2021 02:40 PM
How much is a functional 10 hp Kohler on a 108 worth with a non-functional 108 tractor attached? (clutch needs total replacement, tires questionable, various other little problems, all fixable for someone more skilled and motivated than me.) Northern MN.
mickb72 10-22-2021 09:35 AM
cub
I've seen running 10hp motors go for $100. Maybe a little more if the pto works. Mike
Wayne 10-22-2021 10:45 AM
Thanks. the only catch is they have to take the tractor too, but hopefully that won't be a problem. I have heard of people paying 200 for IH cubs in my area running or not, but I can't substantiate that rumor
Cubcadet_107 10-22-2021 11:05 AM
Its probably a good $2-300 machine if the engine runs, maybe $350 depending on if any attachments or a creeper is present. Clutch rebuild is a relatively simple task and common issue for those more experienced with Cubs.
finsruskw 10-22-2021 11:11 AM
$100 can go down the tubes rather quickly on a clutch rebuild for parts alone if needed.
Wayne 10-23-2021 10:00 AM
Might be closer to $200 on this one. Its kaput except for the pressure plates
Wayne 12-03-2021 01:36 PM
Sold it for 200.
finsruskw 12-03-2021 02:50 PM
good on you!!
