882 Electrical Issue
Hi All,
So, I have a newly acquired 882 that runs fantastic. However, the PTO shuts off when warm and the lights flicker and turn off when warm. I adjusted the Air Gap and that seemed to help the PTO stay on longer, but eventually the PTO shuts off and the headlights do to. If I wait a few seconds after turning the PTO switch off, it will turn back on but shuts off again after a few more seconds. I also noticed that the headlights shut down also and flicker when this occurs. All this happens after the tractor is warm. Could it be a bad circuit breaker or relay? Thoughts on the issue? Thanks! |
These tractors do have a 12V 40A relay mounted to the right of the generator regulator/inverter on the muffler side of the tractor under the battery on the tray framework. They do get weak over time. They look like this:
MTD part number 725-3090 or 925-3090 |
Before buying a breaker, check all the connections. I had a similar issue and it was corrosion on a connection at the breaker stud as well as another point.
https://www.napaonline.com/en/p/BK_7823116 |
NAPA BK 7823108 is closest to OEM.
| All times are GMT -4. The time now is 04:43 PM. |
