-   -   Tiller question (https://www.onlycubcadets.net/forum/showthread.php?t=60054)
Ridingmowers1 05-30-2022 10:17 PM
Tiller question
I have a tiller on a 1450 that has a chip pulley that destroys belts has anyone here ever used a standard pulley on the gear box mounted to the tractor? The standard pulley isn’t as doesn’t cover the shaft as much as the original one.
finsruskw 05-31-2022 07:33 AM
Which pulley are you talking here?
The input from the mule drive or the output to the tiller proper?
And What do you mean by "standard pulley"?
They all need to be the proper/correct diameter for the correct ratios to work properly.
Billy-O 05-31-2022 07:34 AM
I cannot tell you what you plan to do will work...but....
Is the pulley you want to replace driven by PTO belt, same part as this?
https://www.ebay.com/itm/25539955399...emis&media=COP
You just missed this one. If this eBay item is indeed what you need, I suggest you monitor eBay closely as sometimes sale falls thru or a seller might have another.
Ridingmowers1 05-31-2022 09:46 PM
Tiller question
Yes,that is the pulley I am replacing with one that isn’t quite as deep maybe only covers a inch of shaft not 3 inches. I found one the same diameter and only $17 not $90
finsruskw 06-01-2022 07:08 AM
Let me guess....Hmmmm....$17 huh??
A pot metal farm store item?
That pulley transmits A LOT of torque.
Do you really want something that cheap in that application?
ol'George 06-01-2022 08:06 AM
And may I add ruin a expensive belt!
Go to surplus center.com and get a good quality Browning cast iron pulley for for much less $$$ :beerchug:
R Bedell 06-01-2022 09:08 AM
Now you are talking !!
:ThumbsUp:
Ridingmowers1 06-03-2022 10:00 AM
Tiller question
No it’s a cast iron made in America pulley
finsruskw 06-03-2022 02:17 PM
Let's see it.
Ridingmowers1 06-04-2022 11:15 PM
Tiller question
2 Attachment(s)
http://73D94BCB
Here is the pulley you want to see
