-   -   149 hydro speed limit? (https://www.onlycubcadets.net/forum/showthread.php?t=60078)
Nessmuck 06-05-2022 09:04 PM
Ran it finally today. It seems to have 3 speeds, not, kinda and holy cow!
How do I adjust it to be more between not and normally kinda slow?
Billy-O 06-05-2022 10:58 PM
Interesting Read: https://www.onlycubcadets.net/forum/...ead.php?t=4635
Nessmuck 06-06-2022 12:15 AM
Thank you.
Nessmuck 06-06-2022 05:26 PM
The parts look ok, but do wobble left and right. Is that normal?/
Nessmuck 06-06-2022 06:19 PM
https://photos.app.goo.gl/Ew1s4upmKY7ZmApc9
Billy-O 06-06-2022 10:24 PM
The trunnion plates do look a bit loose, but I think the springs are too loose or weak. Hard to tell in video. I also wonder if you have all the pieces for the trunnion spring... I see two springs and I cannot tell whether if you have both end caps. I think I see one, but can't tell on the other end of springs (towards the rear).
Nessmuck 06-07-2022 01:16 PM
I appreciate that, I'll check.
Nessmuck 06-08-2022 02:17 PM
The spring have both caps, but are loose for and aft. About and 1/8-1/4 of slop. Do I need new springs?
How would I fix the left-right wobble?
Nessmuck 06-08-2022 05:49 PM
My mistake. Not for and aft, starboard and port. Left/Right. I remembered wrong. Definitely a lot of left / right play when it's all added up.
finsruskw 06-08-2022 07:44 PM
Are the caps badly worn into the sides of the trunion slot?
If so, you need a new repair plate
Hydro Trunion Repair Slot
Repair your worn trunion slot without removing the arm from the tractor.
Use this piece to mark your old one, cut it off and weld this one in it's place.
