-   Kohler Engines (https://www.onlycubcadets.net/forum/forumdisplay.php?f=50)
-   -   Engine blow by thru crank case vent (https://www.onlycubcadets.net/forum/showthread.php?t=60250)
amflyer 07-19-2022 08:32 AM
I have a 12 horse engine that does not smoke thru the exhaust. But after about 30 mins of use the engine will start to very lightly smoke thru the crank case vent. Is a rebuild in my future? Engine doe not seem to be using oil. Any suggestions would be appreciated.
R Bedell 07-19-2022 08:37 AM
IF........you want your engine to operate correctly.
:Huh:
West Valley G 07-19-2022 10:11 AM
Had same issue on K301 a while back. It really wasn't using oil either.
Did a rebuild on it and the problem is fixed. I would say a rebuild is
in the future somewhere. Or at least pull the head and the breather
and see what you can see.
Ken
RoseHillFarmIHCC125 07-27-2022 03:08 PM
I had blow by on my K301 as well. I bought a rebuild kit from the guy that saves tractors, and consulted this forum. Great group here, they got me running like a top again.
