-   -   1782 Factory Model Numbers (https://www.onlycubcadets.net/forum/showthread.php?t=60710)
farmer52 12-07-2022 06:32 PM
The 50 Year CC book lists the following factory model numbers for the 1782 SGT:
140-712-100
141-712-100
142-712-100
143-714-100
144-714-100
145-715-100
146-715-100
What is the difference? Does each number signify a different model year?
I apologize if this information is published some where.
Thanks!
Oak 12-07-2022 06:48 PM
14X-712-100 -- X is the year it built in the 90's
712 machines will have the 4.6" PTO
714/715 will have the 6" PTO
They also switched over to a plastic tunnel cover and screens on the side panels somewhere in here too so that will probably be the difference between the 714 & 715. I also believe they switched to a 30MM axle sometime late in the series.
100 is a yellow and white machine (even though that was the only color)
farmer52 12-07-2022 07:36 PM
Thank you very much for that information. I thought it designated different options (tires, hydraulics, etc.). But then I realized there were seven (7) numbers and the 1782 was produced from 1990-1996 = 7 years.
Even my local CC dealer did not know. I will pass this info on to him.
Thanks again!!
R Bedell 12-08-2022 07:04 AM
In summary, the 1782 had three (3) variants, being: 712, 714, & 715.
This is why it is important to look and copy down the information, from the tag on your tractor, so one gets the right parts.
:IH Trusted Hand:
farmer52 12-08-2022 07:24 AM
:IH Trusted Hand:
Agree! Thanks!
darkminion_17 12-08-2022 10:39 AM
There was a 141-713-100 also.
R Bedell 12-08-2022 11:08 AM
And Cub Cadet says....
darkminion_17 12-08-2022 11:15 AM
This book has it in it, may be a printing error.
farmer52 12-08-2022 11:20 AM
The 50 year book (page 94) lists 144-714-100 twice but I do not see 713 listed in the 1782 tractor section.
What book are you looking in?
darkminion_17 12-08-2022 11:25 AM
This one, it only goes up to 1991
