-   -   65 Cub Cadet 100 Plowing Snow (https://www.onlycubcadets.net/forum/showthread.php?t=60740)
HiltzMachineWorks 12-18-2022 07:03 PM
We had a big storm this weekend in Maine. 24+ inches storm total expected by tomorrow morning.
This summer my son bought a 1965 Cub Cadet 100. It has some cosmetic mods, like incorrect headlights, but we’re planning to restore it together. I also have an IH ’49 Farmall Cub and a ’44 Farmall M.
Anyhow, I can’t believe how much this little tank can push the snow! This was a wet heavy snow and it did just fine. It has tire chains, but no wheel weights. We’d like to put double rear wheels on next year, with weight.
I’m not sure what model this plow is, and if anyone can identify it from the video, that would be helpful. The tractor needs to be gone through completely, but it’s amazing how well it did! My son put about 5 hours on it this weekend. It really exceeded our expectations because the snow was just so wet and heavy.
If you’d like to see it, you can see it on the link below. I have other Tractor videos including IH Farmall stuff and a modern MTD Cub Cadet GT54
https://youtu.be/hKOd9CYV5T8
finsruskw 12-18-2022 07:51 PM
That's the standard 42" IH plow by the looks of it.
I'd forget the duals and add some weight instead.
The duals, IMHO, will only be more of a hindrance as you will always be running over an un-plowed path with them.
Unless to step up to a 54" blade.
Sergeant 12-19-2022 06:17 PM
A Late Friend of Mine Bought a Model 70 New In 1963 and all he used for plowing was chains, He never bought any Ballast. He was a Bit on the Cheap side, it had a cigarette lighter But No headlights. I Now Have it and haven't Used it for Plowing snow, though. I bought a 1970 Cub Cadet 106 in 2003 from the widow of a Late Neighbor where I grew up. It came with a QA36A Thrower, which I used for 11 years Until I Bought a snow Blower for My Deere X748 in 2014. Now I have Many Modern Deere and Cub Cadet Machines that I use for snow removal. But have always wanted to try a front Blade On the 106 which I will use this year, if it even snows here. But I run AGs and a Bolens frame weight on the 106. Ran chains & Terra Grips for Years and would also run Deere 50lb wheel weights on the 106, and it was Practically Unstoppable with the frame weight & 50Lb wheel weights Throwing snow.
I actually Have 6 tractor's set Up for snow removal this Year
Cub Cadet XT3GSX with 46-inch Front Blade(eventually will be replaced with Bercomac Rotary Broom)
Cub Cadet 2182 with 3point rear Blade
Cub Cadet 106 with 42-inch Front Blade
John Deere 2025R Compact with 60-inch Loader Mounted Blade
John Deere X748 with 47-inch Blower
John Deere GX335 with 48-inch Front Blade
:ThumbsUp:
Tagcab7 12-20-2022 11:36 AM
I used my 102 for snow plowing last year for the first time. I was really impressed too. I have double cast iron wheel weights on ag type tires with chains. It came with a set of turf tires too but I put the ags on for the winter. Not sure if its really necessary but I like the way it looks. I can’t run them in the summer because the deck won’t fit with them on.
Sergeant 12-20-2022 07:48 PM
Since Putting AG's On My 106 in 2016 I actually haven't even tried to see if the deck works or Not with them I Put 23X8.50 AG's On the 106
Farmall450 12-21-2022 04:23 PM
Nice video. I was always impressed what my 1282 would push back when I was your son's age. I threw a plow on the 1811 just for shits and giggles this year...might clean up by the shop with it some :D
Sergeant 12-22-2022 01:36 AM
Boy the amount of snow Keeps Dropping! Your In the 3.8 Inch area and I am In the 3 inch area so that 1811 May Handle Your Plowing needs for this snow fall :ThumbsUp:
Farmall450 12-22-2022 12:27 PM
I have a Western MVP Pro Plus for my Silverado 2500HD :D
But the 1811 w/plow and 1862 w/ blower are fun to play with and make paths. Especially the blower unless it is windy out.
Sergeant 12-22-2022 02:29 PM
When I Lived In NY a Plow On a Pick Up was Useless On My driveway Unless You Plowed during the storm If You didn't. You Needed a thrower or Blower. When One Highway Guy( former soldier of Mine) was working His Highway truck could Handle the driveway after 48-inches of snow fell. I got rid of My truck Plow Years ago. It would Probably be fine where I Live Now. But Back In New York it was a Useless thing to Me On My GMC K3500 Traded that In for a Nissan compact Pick Up and Got rid of the Plow with It
Sergeant 12-23-2022 01:52 AM
Well None of the Cubs did snow removal Today, Just too darn cold this evening, ended Up Using My JD 2025R with Loader Mounted Blade and Heated Tektite Cab:ThumbsUp:
