| Jim in SC |
04-14-2023 08:14 PM |
Need help with K161
2 Attachment(s)
This is a new to me K161S engine. The engine was not running when I got it and it had a bad oil seal on the flywheel side, which I replaced. After replacing the seal I buttoned up the engine and was going to replace the points. When I went to install the points plunger, it goes in fine, but it will not go in far enough to allow the points assembly to be installed. I watched it as it rides the cam and it goes through the open and close cycle fine, the plunger just appears to be too long. I cannot see that anything is out of whack with the cam or inside the block. This is my first 7 HP Kohler - does it require a shorter points plunger than a K241? here's a couple of pictures
