-   -   782D Overheat and cooling issues? (https://www.onlycubcadets.net/forum/showthread.php?t=61189)
easttncub 05-10-2023 06:36 PM
Hello. New to me 782D. Recently fan stopped turning. I can press belt (with stick) and it will engage pullies and begin turning fan. Makes bad bearing noise. Engine temp reached upper limit on gage. Also need to clean screen and radiator.
What is best option for bearings / water pump? Should I replace water pump while there also? Could I just replace bearing?
Thank you for your help.
CubDieselFan 05-10-2023 07:15 PM
The bearings at the fan can be replaced. There is a parts breakdown on the Cub Cadet parts and service link above.
Is the noise coming from the front of the engine? The water pump is in the rear. If you replace the water pump, get a belt too.
What part of Tennessee are you in?
CubDieselFan 05-10-2023 07:19 PM
Make sure the top radiator hose has the insulation on it. It will overheat if that is missing too. The cooling system on thr D600’# in the 782D and 1572 is at the edge of being good enough to keep the engine cool. Any little thing wrong can make them run hotter. They made the radiator thicker in the next series diesels. That started with the 1772.
Oak 05-10-2023 10:37 PM
Easttncub, the fan bearings are replaceable. Here's a pic of one I did.
Attachment 112748
There were 2 styles of fan supports. One was made from steel and the other was aluminum. Mine is cast aluminum and it took (2) R12RS bearings like this link but make sure they are double sealed.
https://www.ebay.com/itm/30303186345...3ABFBMvu_riYFi
You need to check your idler pulley also because they go bad too. I think this is the correct part#. IH-61176-C92
Here are the Gates brand belts for your machine.
Fan #6727
Water pump #7320
Here are the filters I use. These are Wix numbers.
Air = 46270
Fuel = 33389
Pre Fuel = 33972
Oil = 51064
Hydro = 51410
Good luck and lets see some pics of your tractor.
1711Cub 05-11-2023 07:58 AM
IF you need the fan idler pulley, an easy to locate replacement is IH-61176-C92
Replaces 756-3032, which is discontinued.
https://m.media-amazon.com/images/I/..._AC_SX679_.jpg
An easy to locate alternative for the upper hose is one for a Kubota RTV:
https://www.onlycubcadets.net/forum/...1&d=1682811472
Part number K7311-85150
I use Armacell 1" hose insulation purchased at Home Depot.
https://www.onlycubcadets.net/forum/...1&d=1682983863
easttncub 05-11-2023 10:10 AM
782D Overheat and cooling issues? update
Thank you Everyone. Great update on part numbers and steps. Mine is missing the hose insulation.
I believe replacing the bearings and belt will be the answer. I will know more when start the repair.
I am located in Jonesborough, TN. Not too many diesels here that I can tell. This unit was purchased new in Gate City, VA by a local Doctor. I purchased from second owner. Faded paint and some maintenance items to take care of but I have been mowing this season.
