| That_cub_dude1847 |
05-16-2023 04:20 PM |
Cub Cadet Original Leaky tailshaft
Hi all
I gave my Cub Cadet Original all new oil seals in the rear in October 2021 and rebuilt the rest of the trans in April 2022. After that I has absolutely no issues with the transmission at all. That was until yesterday when I was cultivating with it and there was a very constant stream of fluid coming from what appeared to be the tail shaft where the clutch driveshaft meets the arm coupling which leads into the transmission. A drip about every second and when I drive forward then put then put the brakes on, a very steady stream of fluid then back to drips. I replaced the oil seal there with one I bought from NAPA that was a near perfect fit. Fit inside the hole perfectly and fit over the shaft perfectly as well. Has anyone had a bad history with these seals? From what I can tell it looks fine and I know they don't need frequent replacing given that the seal I took off before the NAPA one was the original IH seal. Its also worth mentioning that this tractor would drip a lot when i first got it. If I where to leave it on a cement surface overnight, A puddle of about 5 inches would form underneath it and leak at the same location. After I replaced that seal I had no more dripping but after yesterday, if I where to park it and let it sit on a cement surface for about 5 minutes, a puddle of around a foot to a foot and a half would form. Any ideas? There's no strange rumbling sounds from underneath the tractor and the drive shaft is as straight as an arrow. I have no clue what could have compromised this.
