K181 parts in a k161 block
I have a large bore k161 block that threw a rod and ruined the crank pin on crankshaft. Does anyone know if I can use the crankshaft and rod from a k181 with out any issues? I have access to those k181 parts and from my parts searches and looking around google it looks like the rod and crank are the only differences between the k161 and k181 (as long as the k161 isn't the small bore). Just want to check the minds on here to see if i am missing something and it wouldn't work. Thanks
Wiseguy33, i got a good running k161 in a IH 73. its the last of my resto projects. i live near douglassville. if you are close . i,m not quite sure what direction i,m going with the 73 yet. you can check it out , make a deal.
| All times are GMT -4. The time now is 04:13 AM. |
